https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> current measurement in hspice ---issue https://designers-guide.org/forum/YaBB.pl?num=1144461217 Message started by curious on Apr 7th, 2006, 6:53pm |
Title: current measurement in hspice ---issue Post by curious on Apr 7th, 2006, 6:53pm Hello all, I was measuring the current through a source. So when the current is flowing in to the souce it should plot positive current but it plots the current is negative. I am attaching the circuit which I am talking about. Please let me know what the problem is? Thank you, c |
Title: Re: current measurement in hspice ---issue Post by Geoffrey_Coram on Apr 25th, 2006, 5:46am You might want to check your Hspice manual on sign conventions. Eg, I recall that current into a MOS drain is positive, but current *out* of the source is positive. |
