https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> error amplifier specs in ldo https://designers-guide.org/forum/YaBB.pl?num=1145366396 Message started by chethan on Apr 18th, 2006, 6:19am |
Title: error amplifier specs in ldo Post by chethan on Apr 18th, 2006, 6:19am Hi all, I am supposed to design an LDO with 1.5V ( Fixed) output and a max current of 150mA. How should i find out what gain I need for my error amplifier. How can i decide upon the specifications for error amplifier like GBW, slewrate etc. can someone help me on this. any materials regarding the same would be very helpful. |
Title: Re: error amplifier specs in ldo Post by Visjnoe on Apr 18th, 2006, 10:59am Hi, Here's a link to Rincon-Mora's website, containing lots of stuff about CMOS LDO's: http://users.ece.gatech.edu/rincon-mora/ Kind Regards Peter |
Title: Re: error amplifier specs in ldo Post by raul on May 2nd, 2006, 6:34pm Your gain is set by your line regulation(PSRR at 0Hz) or your load regulation, whichever is worse. Try the slow P or weak P corner at maximum temperature and this will tell you the worst case gain for a weak power device. The bandwidth is set by either the max Iq available or your PSRR over frequency requirement(Audio usually requires 60 dB @20KHz) since you need to have loop gain at the frequency you want rejection. There are all sort of tricks; dynamic biasing of certain key blocks in the LDO proportional to load current, ways to compensate the loop, interesting architectures for any load capacitor stability, etc... The smaller your load capacitor, the faster your linear loop needs to be in order to avoid the output voltage from dropping, dynamic biasing usually helps here a lot. |
Title: Re: error amplifier specs in ldo Post by grosser on May 5th, 2006, 10:59am chethan wrote on Apr 18th, 2006, 6:19am:
in prof. Mora's publications you have formulas, which relates GBW to time response, gain to load regulation... there is an article: Relationship between frequency response and settling time of operational amplifiers- google it regards |
