https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> about video decoder clamp &AGC circuits https://designers-guide.org/forum/YaBB.pl?num=1146538156 Message started by byellow on May 1st, 2006, 7:49pm |
Title: about video decoder clamp &AGC circuits Post by byellow on May 1st, 2006, 7:49pm what is the fuction of clamp &AGC in video decoder circuits how to design? thanks |
Title: Re: about video decoder clamp &AGC circuits Post by gitarrelieber on May 2nd, 2006, 2:20am The clamp circuit is responsible for adjusting the input voltage dc level. The video input is AC coupled to chip through a capacitor. Normally the clamp circuit is a current DAC, which charges or discharges the coupling capacitor. You probably will need some sophisticated digital system to control the clamp circuit and so is the AGC. Maybe you can obtain more details on the hardware implementations in the following reference. http://www.semiconductors.philips.com/acrobat_download/datasheets/SAA6713H_2.pdf With regards, Jiawen Hu Analog Design |
