https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> question in multibit sigma delta modulator https://designers-guide.org/forum/YaBB.pl?num=1146969606 Message started by glacieryy on May 6th, 2006, 7:40pm |
Title: question in multibit sigma delta modulator Post by glacieryy on May 6th, 2006, 7:40pm Hi all, I want to design a multibit MASH sigma delta modulator.I know in most case ,the multibit DAC is used in the last stage,but now I want to use multibit DAC in every stage and I know in the first stage I should use DEM to shape or average the nonliearty caused by DAC. The question is how to decide the bit number of DAC in every stage. Thanks in advance. Best regards glacier |
