https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> How to plot a MOS's Vth vs TEMP curve? https://designers-guide.org/forum/YaBB.pl?num=1147336739 Message started by cirand on May 11th, 2006, 1:38am |
Title: How to plot a MOS's Vth vs TEMP curve? Post by cirand on May 11th, 2006, 1:38am Can I use Spectre to get the Vth-T curve and some other MOS parameters such as mobility-T curve? and How to ? |
Title: Re: How to plot a MOS's Vth vs TEMP curve? Post by ACWWong on May 11th, 2006, 4:17am you can do a parametric analysis with temp and plot the operating point of the transistor from the calculator. for example plotting: OP("/M0","vth") after the parametric simulation will give you what you want. I'm not sure how you can do it using the DC sweep temp function alone. |
Title: Re: How to plot a MOS's Vth vs TEMP curve? Post by cirand on May 11th, 2006, 8:26pm thanks, it works using the parameter analysis. but using the DC temp sweep , i can get only one point, not a vth-T curve. why?... |
Title: Re: How to plot a MOS's Vth vs TEMP curve? Post by S. Badel on May 12th, 2006, 5:20am That's because you are picking data from the operating point analysis (dcOp) which is run once at the beginning of the simulation. When doing a parametric sweep, you are actually running multiple simulations, so the operating point is saved for each point and you can get a curve. as for other parameters, getData("/M0" ?result "dcOp")~>? will list all dc operating points parameters that are available such as gm, gds, vdsat etc. all should be documented in the simulator's reference manual. stéphane |
Title: Re: How to plot a MOS's Vth vs TEMP curve? Post by Marc Murphy on May 12th, 2006, 7:57am cirand wrote on May 11th, 2006, 8:26pm:
Add a command to your netlist like this (via including an extra file): save m0:all and it will save all the swept operating points, allowing you to do the plot you want. This works for me! Cheers, Marc |
Title: Re: How to plot a MOS's Vth vs TEMP curve? Post by ellarguero on Oct 26th, 2012, 2:38pm Hello Guys, I face the same problem, i need to draw mobility versus Vgs from a DC OP i simply can't find this info. there is U0 which is the mobility at zero bias , but i need to draw the dependance on Vgs Any suggestion appreciated |
