https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> saving mulitple operating points in spectre tran https://designers-guide.org/forum/YaBB.pl?num=1148379241 Message started by kmoore on May 23rd, 2006, 3:14am |
Title: saving mulitple operating points in spectre tran Post by kmoore on May 23rd, 2006, 3:14am Hi, Spectre question: I would like to save a number of operating point state files from in a very time consuming transient simulation I'm running so that I can then run ac analysis using the "prevopoint=yes" option for AC analysis at each timepoint. As I undertand it, the ac analysis will use the spectre.fc file created at the end of a transient sim when "prevopoint=yes". So how can I create spectre.fc files at specific time points during the one transient sim? I see in the transient options form that there is a parameter "infotimes" which can be used to save the full dc operating point as a binary at specific time points. But as far as I can see the ac analysis needs a textfile in the same format as the spectre.fc. Any ideas on this? thanks, Kevin. |
Title: Re: saving mulitple operating points in spectre tr Post by sheldon on May 30th, 2006, 5:06am Kevin, Have you tried the acnames and actimes option for transient analysis? Of course you need to be using a recent version of Spectre. Best Regards, Sheldon |
