https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> TR in the Hspice for BJT https://designers-guide.org/forum/YaBB.pl?num=1148387216 Message started by XORGate on May 23rd, 2006, 5:26am |
Title: TR in the Hspice for BJT Post by XORGate on May 23rd, 2006, 5:26am What is the TR in the Hspice for BJT ? How to estimate? Thanks! |
Title: Re: TR in the Hspice for BJT Post by Andrew Beckett on May 29th, 2006, 5:13am This question may mean something to you, but I doubt it means much to anyone else! Can you expand such that somebody might stand some chance of figuring out what it is you're asking? Otherwise you're unlikely to get an answer. Regards, Andrew. |
Title: Re: TR in the Hspice for BJT Post by mikki33 on May 29th, 2006, 7:38am TR stands for base charge storage reverse transit time. Level 1and Level 2 have default value is zero. Level 4 has default value 1e-11 seconds. For Level 8 model TR is time constant for inverse operation (default equals 1e-9 seconds). For Level 9 TR is reverse transit time (default is 0). For Level 11 TR is reverse charge storage time, intrinsic BC diode (default is 0). |
