https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Ocean Commands Cadence GUI uses https://designers-guide.org/forum/YaBB.pl?num=1148941089 Message started by schehrazi on May 29th, 2006, 3:18pm |
Title: Ocean Commands Cadence GUI uses Post by schehrazi on May 29th, 2006, 3:18pm Hi, Is there any way to figure out which Ocean commands the Cadence direct plot GUI uses for plotting things? For example, assume I want to plot IIP3 of a circuit, after running the PAC/PSS simulation, I use PAC direct plot window, select the tones and output and it plots it. All these can be done with a few Ocean commands as well. Is there an option which if set, shows the Ocean commands in CIW or anywhere else? thank you |
Title: Re: Ocean Commands Cadence GUI uses Post by ACWWong on May 29th, 2006, 3:56pm When using ADE & plotting with the Main Form, there is a button near the bottom called "Add to Outputs". If you tick it then proceed to plot your results from the Main Form GUI, you get the expressions loaded into the ADE outputs. You can then paste them in/out of the calculator or in your case, just paste into your Ocean script or simply "save script" once the correct outputs in ADE have been setup. |
Title: Re: Ocean Commands Cadence GUI uses Post by schehrazi on May 29th, 2006, 5:33pm Thank you so much, this helps me a lot. ;) |
