https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> transient converge problem https://designers-guide.org/forum/YaBB.pl?num=1149005856 Message started by danda821 on May 30th, 2006, 9:17am |
Title: transient converge problem Post by danda821 on May 30th, 2006, 9:17am My foundry just update design kit from BSIM3v3 to BSIM4v4. My oscillator can not converge in transient and pss simulation. It converges easily with old BSIM3v3 kit. I am using icfb 5.1.41. I am wondering do I need to change the simulator setup when I migrate from BSIM3v3 to BSIM4v4. Thanks. |
Title: Re: transient converge problem Post by Geoffrey_Coram on May 31st, 2006, 9:50am You shouldn't need to change anything. Did you do any sanity checks on the new models? Eg, run Id/Vd curves and make sure they look similar. |
