https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Spectre results significantly vary with errpreset https://designers-guide.org/forum/YaBB.pl?num=1149698438 Message started by oehmen on Jun 7th, 2006, 9:40am |
Title: Spectre results significantly vary with errpreset Post by oehmen on Jun 7th, 2006, 9:40am I have some trouble simulating a transformer. I have simulated a transformer with different errpresets. Input to the transformer is pulse source. After switching, the output shows some rf-oscillations before it settles. These oscillations strongly depend on the errpreset. Using errpreset=liberal comes closest to measurements! Moderate or conservative yields in a low attenuation of the rf-oscillations, whereas liberal yields in a short overshoot -just as measured! I expected conservative to be as most accurate. So, I am losing faith in simulation ... Do I need to apply some tricks for this special case or for transformers at all? I would be very grateful, if someone could share his experience with me. Below is the netlist. Many thanks, Joerg // Function generator Vin (IN 0) vsource type=pulse val0=10 val1=-10 period=20e-6 width=10e-6 rise=1e-8 fall=1e-8 Rin (IN P1) resistor r=50 Rgen (P1 0) resistor r=50 // Transformer Lleak1 (P1 P1a) inductor l=3.5e-6 Lmag (P1a 0) inductor l=3.27e-3 T_1 (P1a 0 S1a S2) transformer n1=40 n2=40 m=1 Lleak2 (S1a S1) inductor l=3.5e-6 Cwind (0 S2) capacitor c=225e-12 Rwind (0 S2) resistor r=100e6 // passive probe Cprobe (S1 S2) capacitor c=7e-12 Diff (vdiff 0 S1 S2) vcvs gain=1 //simOptions options diagnose=yes rawfmt=psfascii rawfile="results" pivotdc=yes pivrel=0.5 saveOptions options save=all currents=all tran tran start=0n stop=100e-6 errpreset=liberal |
Title: Re: Spectre results significantly vary with errpre Post by bernd on Jun 8th, 2006, 1:23am The errpreset has set the integration method and other parameters for you analysis, this can have a influence on how your circuit simulation behaves. Refer to the docs: Spectre Circuit Simulator User Guide Spectre Circuit Simulator Reference -- 3. Analysis Statements Or probably buy Kens Book - The Designer's Guide to SPICE and Spectre http://www.designers-guide.org/Books/ Bernd |
Title: Re: Spectre results significantly vary with errpre Post by oehmen on Jun 8th, 2006, 3:02am Thank you for the answer, Bernd. I know, that it sets the integration method and I have checked each method. I have been quite surprised, that the results differ that much. That raises the question, which method can I trust and which not? If I design a converter, do I have to do something against these rf-oscillations or not? Are these oscillations are real or just fictitious? Which are the right parameter settings for the simulation? Usually, errpreset=conservative should results in an higher accuracy, right? I would be very grateful for further comments on this topic! Many thanks, Joerg |
Title: Re: Spectre results significantly vary with errpre Post by sheldon on Jun 8th, 2006, 5:16am Jeorg, Are you sure that your transformer model is correct? Here is a slightly modified version of the transformer model. The winding resistance is now in series with the leakage inductance and the winding capacitance shunts the secondary. Also, the probe resistance and the primary resistance and capacitance have been added. The other comment is that the moderate error preset uses trap integration and is susceptable to ringing. You can use the moderate preset with gear2only integration and get good results, see the attachment. Best Regards, Sheldon // Function generator Vin (IN 0) vsource type=pulse val0=10 val1=-10 period=20e-6 width=10e-6 rise=1e-8 fall=1e-8 Rin (IN P1) resistor r=50 Rgen (P1 0) resistor r=50 // Transformer Rwindp (P1 P1b) resistor r=0.01 Lleak1 (P1b P1a) inductor l=3.5e-6 Cwindp (P1a 0) capacitor c=225p Lmag (P1a 0) inductor l=3.27e-3 T_1 (P1a 0 S1a S2) transformer n1=40 n2=40 m=1 Lleak2 (S1 S1b) inductor l=3.5e-6 Cwind (S1a S2) capacitor c=225e-12 Rwind (S1a S1b) resistor r=0.01 // passive probe Cprobe (S1 S2) capacitor c=7e-12 Rload ( S1 S2) resistor r=10M Rdummy (S2 0) resistor r=10G Diff (vdiff 0 S1 S2) vcvs gain=1 //simOptions options diagnose=yes rawfmt=psfascii rawfile="results" pivotdc=yes pivrel=0.5 saveOptions options save=all currents=all tran tran start=0n stop=100e-6 errpreset=moderate method=gear2only step=100n |
Title: Re: Spectre results significantly vary with errpre Post by sheldon on Jun 8th, 2006, 5:18am Having some trouble attaching |
Title: Re: Spectre results significantly vary with errpre Post by oehmen on Jun 19th, 2006, 9:01am Thank you, Sheldon! The transformer model should be correct (the capacitance has been measured between primary and secondary side). Due to the trifilar winding, the interwinding capacitance should be very low. Furthermore, I have omitted the resistances as the impact on simulation results is quite low. But indeed, your simulation results look like my measurements. The differences in your simulation results are quite low compared to my simulation results. Up to now, I have not been able to measure the interwinding capacitance as I did not find any resonance frequency. These capacitance seems to be the key for a successful simulation. Hence, I will take a closer look at the transformer model. Wish, it would be easier to get all these transformer's parasites. What stays is, that I will feel quite unconfident about simulation results when simulating circuits with large inductances and I will check all integration methods and errpresets. Many thanks, Joerg |
