https://designers-guide.org/forum/YaBB.pl Measurements >> RF Measurements >> ac source adding white noise? https://designers-guide.org/forum/YaBB.pl?num=1149770097 Message started by cybq on Jun 8th, 2006, 5:34am |
Title: ac source adding white noise? Post by cybq on Jun 8th, 2006, 5:34am hi all, How to adding the white noise to the ac source in cadence to simulate the input SNR? Thks in advance. cybq |
Title: Re: ac source adding white noise? Post by Jess Chen on Jun 8th, 2006, 8:03am That's what the "port" device is for. Replace your ideal source with a port device. |
Title: Re: ac source adding white noise? Post by mkaragou on Jun 8th, 2006, 8:15am or connect a resistor with the input of a vcvs(voltage controled voltage source) and place the output of the vcvs in series with your ac source |
