https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> choice of the clock of the SC-CMFB https://designers-guide.org/forum/YaBB.pl?num=1150432557 Message started by baohulu on Jun 15th, 2006, 9:35pm |
Title: choice of the clock of the SC-CMFB Post by baohulu on Jun 15th, 2006, 9:35pm HI, if I design a 100MS/s pipelined ADC, and I use a opamp with a SC-CMFB, should I choose the clock of the SC-CMFB as 100MHz? if it is sure. because the common used 6_switched_4_capacitors SC-CMFB can be equavilent as a switched resistor, with a value having the order of 1/(fclk*C), so if the fclk=100MHz, if I want to get a high switched resistance, say 100K, I have to choose the capactior value as 1/(100M*100K)=100fF, and this resistance is paralleled with the output resistance of opamp. so if I want to get a high gain, I need high output resistance , thus high the switched resistance, thus a much smaller capacitor in the SC-CMFB, right? but if the capacitor of the SC-CMFB goes too small, can it kick the disturbance of the paracitic capacitors? regards |
Title: Re: choice of the clock of the SC-CMFB Post by ywguo on Jun 20th, 2006, 8:33am Hi, Baohulu, Sure you can select a smaller capacitor in SC-CMFM. However, I don't understand what you said the disturbance of the parasitic capacitor. Thanks Yawei |
