https://designers-guide.org/forum/YaBB.pl Modeling >> Semiconductor Devices >> Body-effect, depletion width, and band-bending https://designers-guide.org/forum/YaBB.pl?num=1151244232 Message started by Croaker on Jun 25th, 2006, 7:03am |
Title: Body-effect, depletion width, and band-bending Post by Croaker on Jun 25th, 2006, 7:03am For Vsb=0, Vth=2*phi+Qdep/Cox The energy bands Ei and Ef have a difference of 2*q*phi representing that the surface of the silicon has the same concentration as the bulk, but a different polarity. The depletion charge is given by: sqrt(2*e*Nsub*q*V), where e is the dielectric constant and V is the voltage across the negative charge half of the junction, i.e. from bulk to surface...V=2*phi. Now, when Vsb!=0, Vth changes to: Vth,bias=2*phi + Qdep,bias/Cox where Qdep,bias=sqrt(2*e*Nsub*q*V) where now V=2*phi-Vbs I am confused, because I would think Vth,bias=2*phi-Vbs + Qdep,bias/Cox. That is to say, Qdep changes because of the applied voltage, so it would seem like the difference between bulk and surface would also change to 2*phi-Vbs. But, this isn't correct...I looked it up in my Streetman devices text. So, why does the difference between Ei and Ef still have to equal q*2*phi? I would say because the surface still needs to have the same concentration of negative charge for strong inversion. I think what's confusing me is that the voltage from bulk to surface remains at 2*phi, but the voltage that defines the depletion layer charge has changed to 2*phi-Vbs. If the voltage difference between bulk and surface is 2*phi, how can the voltage defining the depletion layer simultaneously be 2*phi-Vbs??? My explanation is that the charge concentration at the surface remains the same as it was when Vbs=0, but now there is less depletion region charge and more carrier charge. Another way of saying this is the voltage drop across the bound charge has changed, which changes the width of the depletion layer (as evidenced by Qdep,bias), but the total voltage drop between bulk and surface must remain at 2*phi, to maintain the right concentration for strong inversion; the remaining voltage (2*phi-(2*phi-Vbs)=Vbs) is dropped across the mobile inversion charge. Does this make sense and is it correct? Do the energy band diagrams for Ei and Ef look the same for both cases where Vbs=0 and Vbs!=0? I am basing my thoughts on the fact that they remain the same, and the difference is still q*2*phi (which is correct). Thanks, Marc Here is a page with some better versions of the equations: www.colorado.edu/~bart/book/book/chapter7/ch7_4.htm]http://ece-www.colorado.edu/~bart/book/book/chapter7/ch7_4.htm[/url] |
Title: Re: Body-effect, depletion width, and band-bending Post by Croaker on Jun 25th, 2006, 9:19am This applet is pretty cool for showing the energy bands: http://jas.eng.buffalo.edu/education/mos/mosCap/biasBand10.html |
Title: Re: Body-effect, depletion width, and band-bending Post by Croaker on Jun 28th, 2006, 5:21am Did anyone make sense of my long-winded post? :) My real question is, how come the depletion charge is determined by 2*phi-Vbs but the voltage from bulk to surface remains steady at 2*phi? Thanks, Marc |
Title: Re: Body-effect, depletion width, and band-bending Post by mc66 on Jul 9th, 2006, 7:13am I think you use two terminal MOS structure's FUNCTION to explain for real four terminal MOS device is root cause. For me,the simplest way to explain BODY EFFECT is when SOURCE voltage up to large(eg, Vg-Vs<Vt,Vb=0),than at soure end ,there will be pinchoff same as drian end in saturation region,then Vt lift so use the fuction you used to explain the situation what happened in source end is not good i think you can found detail answer in this book operation and modeling of The MOS Transistor , Yannis Tsividis |
