https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> Experience in optimization https://designers-guide.org/forum/YaBB.pl?num=1151942794 Message started by Visjnoe on Jul 3rd, 2006, 9:06am |
Title: Experience in optimization Post by Visjnoe on Jul 3rd, 2006, 9:06am Hello, I'm trying out the built-in ELDO optimizer to optimize a certain circuit's performance. However, this can only be run in 1 corner and one should be aware not to converge to a design point that produces nice results in typical, but is bad over corners/Monte Carlo. Anyhow, I was wondering if u have good/bad experience with using this kind op optimizers? I think Cadence also has this (Neolinear heritage)... Kind Regards Peter |
