https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> ADC and DAC https://designers-guide.org/forum/YaBB.pl?num=1152084991 Message started by Omkar on Jul 5th, 2006, 12:36am |
Title: ADC and DAC Post by Omkar on Jul 5th, 2006, 12:36am Hi all, Has anybody used following devices? What are the experiences? What are the advantages and disadvantages? 1. ADC: MAX1147 2. DAC : DAC7664 I am at design stage. I will be very much thankful to you for the information. Regards, -Omkar |
Title: Re: ADC and DAC Post by ywguo on Jul 12th, 2006, 11:30pm Omkar, You'd better go to the company's website to see the relative datsheets and application note. Yawei |
Title: Re: ADC and DAC Post by loose-electron on Aug 1st, 2006, 6:42pm Good points above - But in addition to the specs and apps notes, ask for the lab characterization reports on the devices. Frequently you need to go poking around a bit before they will hand those over, but if you are serious about using the part they will eventually. Jerry |
