https://designers-guide.org/forum/YaBB.pl Design Languages >> VHDL-AMS >> Delta delay in a procedure?? https://designers-guide.org/forum/YaBB.pl?num=1153998009 Message started by hskim on Jul 27th, 2006, 4:00am |
Title: Delta delay in a procedure?? Post by hskim on Jul 27th, 2006, 4:00am HI.. I am a VHDL beginer, some question..ㅠㅠ doing the simulation.. If used signal assignment in a procedure(sequential subprogram), does delta delay apply to it(alike in a sequential process)?? If assign signal after delta time, when does signal assign?? Does it happen after procedrue finished(END)?? |
