https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> A basic question? https://designers-guide.org/forum/YaBB.pl?num=1155028984 Message started by average on Aug 8th, 2006, 1:23am |
Title: A basic question? Post by average on Aug 8th, 2006, 1:23am Does the mosfet have the channel_length modulation effect when it operates in the triode region? Green |
Title: Re: A basic question? Post by jeffyan on Aug 8th, 2006, 1:47am average wrote on Aug 8th, 2006, 1:23am:
hi, as i know, the channel_length modulation effect is defined in mosfet's saturation region. jeff.yan |
Title: Re: A basic question? Post by loose-electron on Aug 8th, 2006, 9:23am Channel length modulation is applicible only in saturation region. You need to have a pinch off scenario in place, so that the pinch off location changes. When you are in triode region the entire channel is inverted (drain to source fully) so length modulation is not applicable. hope that helps Jerry |
Title: Re: A basic question? Post by ACWWong on Aug 8th, 2006, 9:56am loose-electron wrote on Aug 8th, 2006, 9:23am:
When you are in triode region, the entire channel is indeed inverted, but you can still have pinch-off due to velocity satuation (short channel effect). Although this is not "channel length modulation" in the traditional sense, the velocity saturation point is dependant on Vds, so the effects are similar to channel length modulation (ie, you see the knee in the Ids vs vds graph within the triode region). This effect only occurs (as the name depicts) on short channel devices/high field strength situations. |
Title: Re: A basic question? Post by loose-electron on Aug 8th, 2006, 10:18am Well yes, agreed - But there is a lot of bad information in textbooks on velocity saturation Pinchoff Region � Electron carriers in the pinched-off region are velocity saturated, Many texts use the illustration: "velocity saturation is similar to a gas under pressure traveling through a very small tube� I still don't know who the originator of that one is. It is a nice illustration, but not valid. Carrier velocity saturation is caused by horizontal electric fields to the channel. end. � For an in depth discussion see: "Carrier Mobility and Current Saturation in the MOS transistor" IEEE Transactions on Electron Devices, March 1965. I wish I had an e-copy of the above, but it predates most computers. - Jerry |
Title: Re: A basic question? Post by average on Aug 8th, 2006, 4:57pm I think your replies are very helpful for me, thanks all. |
Title: Re: A basic question? Post by qiushidaren on Aug 21st, 2006, 12:46am jeffyan wrote on Aug 8th, 2006, 1:47am:
I agree with you, jeff. |
