https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Mixed signal simulation time https://designers-guide.org/forum/YaBB.pl?num=1156247607 Message started by mady79 on Aug 22nd, 2006, 3:53am |
Title: Mixed signal simulation time Post by mady79 on Aug 22nd, 2006, 3:53am I m working on mixed signal simulations with digital (rtl) and analog( ams ) .I appreciate if there are some ways to make the simulation faster by changing parameters like reltol ,time scale in AMS .. My digital logic is small ,does wrting that digital in ams and having all ams models heps in simulation time ?? just curious ... Thanks in advance ... |
Title: Re: Mixed signal simulation time Post by jbdavid on Aug 29th, 2006, 10:13am in Cadence you can use a profiler to see where the simulator is spending its time.. Generally speaking simulator time is Behavioral < RTL < Gate, but ALL of those are much faster than solving the analog circuit.. to get the most speed out of Verilog-AMS I look for places where the analog data is SAMPLED, or can be treated like a sampled system.. for those I use WREAL rather than electrical.. as this moves the signal out of the analog solver. (my Tutorial from BMAS 4 years ago talks about this method a little and my paper from two years ago started the ideas in my head for using logical signals on a differential signal pair.. which I expand on in this years paper.. (there is still time to register.. assuming your in the USA.. or can easily travel here..) Its the Analog simulation that generally consumes the most resources so thats where you need to focus your modeling effort. Jonathan |
Title: Re: Mixed signal simulation time Post by jbdavid on Sep 13th, 2006, 9:44am I try not to give too much advice here.. rather than "That's where you should focus your modeling efforts" I meant rather to share my experience.. "That's where I tend to focus my modeling efforts" jbd |
