https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Ft in ADE->Results->Print->DC Operating Points? https://designers-guide.org/forum/YaBB.pl?num=1156254213 Message started by ayowchen on Aug 22nd, 2006, 6:43am |
Title: Ft in ADE->Results->Print->DC Operating Points? Post by ayowchen on Aug 22nd, 2006, 6:43am Hi all, We are using both Gummel-Poon and HICUM. And Ft in ADE->Results->Print->DC Operating Points is frequently used. Does anyone know how this ft comes from? Such ft result is actually inconsistent with the freq @ H21=1 from AC simulation. :o Many thanks. Ayow |
Title: Re: Ft in ADE->Results->Print->DC Operating Points Post by Geoffrey_Coram on Aug 22nd, 2006, 1:01pm fT in the Gummel-Poon model is gm/(2 pi * (Cmu + Cpi)) and is a lousy approximation. The Hicum model defines a somewhat more sophisticated result, but Mextram has the best derivation of fT using all the partial derivatives of the various quantities, considering the non-idealities and internal nodes (internal base, collector) of the model. That said, most people don't actually look at the frequency where H21=1, because if you have a zero in the response, it may level off instead of crossing 0dB. You're better off using the Gummel formula freq / imag(1/H21) at a frequency slightly above the 3dB point (the corner frequency). |
