https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Sensitivity Analysis issue https://designers-guide.org/forum/YaBB.pl?num=1156411722 Message started by philgolden on Aug 24th, 2006, 2:28am |
Title: Sensitivity Analysis issue Post by philgolden on Aug 24th, 2006, 2:28am Hey, I have been trying to simulate a SENS sensitivity analysis of an amplifier circuit with Spectre, specifically the sensitivity of the output voltage to various component parameters. When I try to verify the SENS sensitivity given wrt a certain resistor resistance, the number is a factor of 5 higher than the 'sensitivity' that I calculate by doing a parameter sweep of resistor values around the operating point (i.e. just plotting dV/dR). I am working with partial sensitivity values from the SENS analysis (of course I have the same issue with normalised sensitivity). I would be most grateful for any insight into what may be causing this. Phil |
