https://designers-guide.org/forum/YaBB.pl Modeling >> Semiconductor Devices >> Any mechanism in bipolar layout like the latchup https://designers-guide.org/forum/YaBB.pl?num=1156744913 Message started by jaylin79 on Aug 27th, 2006, 11:01pm |
Title: Any mechanism in bipolar layout like the latchup Post by jaylin79 on Aug 27th, 2006, 11:01pm Hi guys I am debugging an IC which is designed with bipolar transistors, it is a driver IC, can output 0-18V pulse with +/- 2A current, but the testing result is the output can not be higher than 10V, if the output is higher than 8V, there is average 50-60mA IC power current, and the IC will be burned soon, even though there is a few IC can output 18V, there is still 33mA power current when it output 18V that is much higher than its designed value, does anybody have the experience like this? please tell me. thanks in advance. |
Title: Re: Any mechanism in bipolar layout like the latch Post by sheldon on Aug 28th, 2006, 6:15am Jaylin, Could you provide more details about the driver design? 1) Is it all npn? Or npn-pnp? 2) Do you really expect the output to swing rail-to-rail, 0 to 18V? 3) How was the interconnect routed? Also could you describe what you mean by burned out? Does the interconnect fail? Do the base-emitter junctions short? These are useful clues in understanding the source of the issue. There are a lot of bad things that can happen with bipolars. a) Bipolars saturate and this limits the maximum swing range. In logic applications, Schottky diodes connected in reverse across the Base-Collector junction to prevent saturation. This limits the minimum output voltage to about Vbe-Vd,schottky. In general, it is hard to build an integrated high voltage Schottky and the package parasitics limit the usefulness of off-chip clamps for power designs. b) When the bipolar saturates the parasitic, substrate pnp turns on and draws a lot of current. The buried N+ layer that forms the subcollector reduces collector series resistance and suppress substrate pnp beta reducing the likelyhood of latch-up. c) There is some optimization involved in the placement of the isolation rings. If the isolation rings are placed to close, then the substrate- buried collector breaksdown and limits the output swing. If the isolation ring and substrate conatc are placed to far from the device then they don't short the substrate pnp B-E junction contributing to latch-up. d) Routing interconnect is big challenge, the metal has to routed so the the interconnect resistance does not contribute to the voltage drop, does not fail due to electromigration. The interconnect to each emitter needs to be identical or the difference in Vbe will cause hot spots. Ideally, small resistors, "ballast resistors" are used to equalize the Vbe. e) Bipolars are sensitive to secondary breakdown, you will need to ask the big brains to describe the physics. Basically, if the transistor is an 18V transistor and the transistor can source and sink 2A does not mean the it can source and sink 2A at 18V. Usually it can handle a lot less. f) Finally, you have not described the process junciton isolated or dielectrically isolated? Dielectrically isolated devices are more susceptable to device self-heating and thermal run-away. g) What type of packaging are you using, are the dies thinned? How are the dies mounted in the package? Are you testing at full power at wafer test? Best Regards, Sheldon |
Title: Re: Any mechanism in bipolar layout like the latch Post by loose-electron on Aug 28th, 2006, 9:06am Yes please give us some more information here on what is happening - Sheldon has the right set of questions. Also, the 2 things that come to mind immediatly are back biased bulk diodes breaking into a zener state, and hot Vbe junctions in non ballast layouts of NPN power transistors. But there are a heap of other issues as well. Need some more information on what is going on. |
Title: Re: Any mechanism in bipolar layout like the latch Post by jaylin79 on Aug 29th, 2006, 8:15am Dear Sheldon & Jerry, Thanks for your kindly suggestion. There is more information: 1)It is all NPN struture. 2)the output swings from Vce_sat to VDD-2*Vbe-Vce_sat. 3)What does "interconnect routed" mean? Do you mean a reasonable metal connection in the layout? I didn't place the ballast resistor at the emitter of the big drive transistor for these small resistor will take great size in the layout,but I put very wide metal2 above the parallel transistors and pick up them one by one. 4)The testing is not wafer testing, the IC is tested on a socket after packaging. 5)The "burned out" I said means that in the testing, I give a 5V input to the IC, and VDD=6V at the first, it will output 4.6V, then I adjust the VDD up to 18V, a few "good IC" can output 16.6V, but Ivdd=34mA (the designed value should be smaller than 1mA, because the load of the IC is capacitor), under such large power consumption 34mA*18V, after 1 or 2 hours, the Ivdd jumps to several mA that is the current limit of the power supplier; but most of the IC is worse, when I increase the VDD up to 10V, the output voltage seems not to follow the VDD but oscillate about 8V, and the Ivdd become larger. 6)the process is juction isolated. 7)+/-2A current is the output peaking current, the during time is smaller than 100nS. 8)the design seems to be digital, but I have not put the schotty diode at the BC juction of transistor to avoid saturation, even for the big transistor at the output. Will it cause great problem? 9)the ground guard ring is not too close and too far from the device, the distance is the same as the minimum distance between islands 10)the package is SOP and is said to sustain more than 600mW power consumption, and the die is some thin L/W=1.7 Thanks a lot ®ards Jay |
Title: Re: Any mechanism in bipolar layout like the latch Post by loose-electron on Aug 29th, 2006, 10:04am Jay: Could you post a schematic of the circuit and comment on what is going on relative to the schematic? thanks, Jerry |
Title: Re: Any mechanism in bipolar layout like the latch Post by jaylin79 on Aug 30th, 2006, 6:08am Dear Jerry, It is not convenient to show the schematic for it is a project, but I am very grateful for your and Sheldon's help. Best Regards Jay |
Title: Re: Any mechanism in bipolar layout like the latch Post by jaylin79 on Sep 10th, 2006, 7:02am Dear Sheldon and Terry I finally got the point that it is because there is 3 transistors whose BE junctions are reversely broken down at 6.5V, one of them limit the base voltage of the upside NPN transistor at the output to Vbe+Vbr, so the output can not be high, when I use a zener diode in serial with 100ohm resistor to bypass the BE junction, the simulation duplicates the testing result most likely. :) Best Regards Jay |
Title: Re: Any mechanism in bipolar layout like the latch Post by loose-electron on Sep 12th, 2006, 11:15am The base emitter junction is going into a zener situation. Due to that being a shallow junction area, thats not too surprising. A lot of models in simulation do not include large signal effects of this nature. Another example of a bad foundry model. |
