https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> Test Plan for AMS https://designers-guide.org/forum/YaBB.pl?num=1157536125 Message started by rahul_iitkgpvlsi on Sep 6th, 2006, 1:48am |
Title: Test Plan for AMS Post by rahul_iitkgpvlsi on Sep 6th, 2006, 1:48am Hi, I'm going to develop a test plan to test the Controller Block of Synchronous DC DC Buck converter driven by MOS gates.The controller has analog and digital both the module. I need to generate the test bench for this controller automatically depending on the given behavioral modelling of the controller.Could you plz provide me any idea so that I can proceed and the test plan should cover all the faults.....? Regards, Rahul |
Title: Re: Test Plan for AMS Post by loose-electron on Sep 7th, 2006, 8:08am Why don't you start with a detailed performance product specification of a similar product, and develop testing to cover all the specification parameters in there? Lots of these type of converters out there, and it serves as a reasonable starting point. |
