https://designers-guide.org/forum/YaBB.pl Modeling >> Semiconductor Devices >> vccs https://designers-guide.org/forum/YaBB.pl?num=1157728316 Message started by jhon on Sep 8th, 2006, 8:11am |
Title: vccs Post by jhon on Sep 8th, 2006, 8:11am Hi guys, I would like to implement a small signa equivalent circuit of a transistor with Spectre.... At the moment the main problem is the voltage controlled current source, :'( I am defining it as follows: source (gi gs di si) vccs gm=GM but I would like to define also the delay time (i.e. tau, gm*exp(-jwtau)). Do you know how I can define this delay time????? :-? Thank u!!!!!!!!! |
Title: Re: vccs Post by Ken Kundert on Sep 8th, 2006, 8:32am Combine the vccs with a delay line (spectre -h delay). -Ken |
Title: Re: vccs Post by jhon on Sep 8th, 2006, 9:30am Hey Spectre, Thanks a lot for your feedback.... But I am completely new with Spectre, how may I combine these functions? I mean...which is the syntaxis??? :-? |
Title: Re: vccs Post by John O Donovan on Sep 8th, 2006, 5:04pm The syntax for all Spectre devices is the same. The get help on the delay device, use "spectre -h delay". Incidently the vccs device also has a "td" parameter which will do what you want, i.e. source (gi gs di si) vccs gm=GM td=TAU Again "spectre -h vccs" explains this. Regards, John |
Title: Re: vccs Post by jhon on Sep 9th, 2006, 3:01am perfect... ;) thank u!!!!! |
