https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Any Guide for Dummy in Coding Verilog A ? https://designers-guide.org/forum/YaBB.pl?num=1158137510 Message started by 337see733 on Sep 13th, 2006, 1:51am |
Title: Any Guide for Dummy in Coding Verilog A ? Post by 337see733 on Sep 13th, 2006, 1:51am Dear ALL, This may sound a bit stupid. I'm trying to look for a simple guide to start to code a model using verilog A. How should i go about doing it? 1.Which compiler is easy to use? Anyone that is free/window-based? 2.There are quite a number of models available for download(a good starting point), how to view it in Cadence or Mentor's tool? That's to help me to kick start the learning curve. Thanks. |
Title: Re: Any Guide for Dummy in Coding Verilog A ? Post by Geoffrey_Coram on Sep 13th, 2006, 5:15am Best starting point is an existing model. Find something close to what you need to build. Are you doing a device model, like a diode? Or a gate-level model? I've never used anything but a text editor to view the model ... not quite sure what you want to see. There is a company (Lynguent) that is developing a GUI for model development. What simulator are you going to run it in? The question about a compiler is probably not relevant - you don't really want to see the C code produced by the compiler, you want the compiled object to run in your simulator. Spectre comes with a compiler; last I heard, Eldo's compiler required a special license. There is an open-source, Win32-based compiler called ADMS, but you need special scripts to convert the output for your favorite simulator, and then you need the license for the C modeling interface. So, I don't think this is what you want. |
Title: Re: Any Guide for Dummy in Coding Verilog A ? Post by jbdavid on Sep 13th, 2006, 10:41am I'd suggest looking at Papers on the BMAS website www.bmas-conf.org.. but if you want the EASY way - signup for the Cadence class. by the end you'll have written 3 or four models. jbd |
Title: Re: Any Guide for Dummy in Coding Verilog A ? Post by 337see733 on Sep 14th, 2006, 4:25am Quote:
Quote:
At this point of time, i have access to Cadence's product. Therefore, i assume i will run in spectre. But, before i finished all my coding(/my model), i would like to view some of the (intermediate)results for debugging...like checking whether the internal function behaviors are right or not.... I'm looking some software/tool that allows me to probe the internal function behavior for debugging purposes. I have all the equations ready in Matlab, but now need to code it in Verilog-A so that i can connect to simulator. I should check the ADMS up, till then...Thanks.... |
Title: Re: Any Guide for Dummy in Coding Verilog A ? Post by Mighty Mouse on Sep 14th, 2006, 7:35am Perhaps I am stating the obvious, but there is also Ken's book on Verilog-AMS: http://www.designers-guide.org/Books/dg-vams/index.html. It has a whole chapter dedicated to introducing and teaching Verilog-A. |
Title: Re: Any Guide for Dummy in Coding Verilog A ? Post by 337see733 on Sep 14th, 2006, 7:51pm Yes..reading that book. ;D |
Title: Re: Any Guide for Dummy in Coding Verilog A ? Post by LRC on Oct 18th, 2006, 7:23am You can find plenty examples of verilog-A in: $CDSHOME/dfII/samples/artist/spectreHDL/Verilog-A The reference doc in CDSDOC is useful material. Good Luck. ;) |
Title: Re: Any Guide for Dummy in Coding Verilog A ? Post by Geoffrey_Coram on Oct 19th, 2006, 4:24am 337see733 wrote on Sep 14th, 2006, 4:25am:
Then you should look at the MOS11 Verilog-A code on this web site (click on the Verilog-AMS link in the upper right). Quote:
In spectre, any variables at module scope are available for plotting with "save M1:all" (assuming M1 is the instance name of your Verilog-A model). Also, spectre supports the $debug() system task so you can print out values of internal variables during the iterations. -Geoffrey |
Title: Re: Any Guide for Dummy in Coding Verilog A ? Post by jbdavid on Oct 22nd, 2006, 10:17am Also don't forget that cadence ADE has the AHDL Debugger - so you can step thru the operation of your model. For AMS - the simvision Gui can be used the same way. I'm still looking for a free simulator that supports verilogA/AMS specifically for student use. Jonathan |
