https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> Debugging 12-bit ADC Silicon https://designers-guide.org/forum/YaBB.pl?num=1158219189 Message started by Faisal on Sep 14th, 2006, 12:33am |
Title: Debugging 12-bit ADC Silicon Post by Faisal on Sep 14th, 2006, 12:33am Hi, We recently got our 12-bit ADC back from the fab. It gives at @12-bit level. DNL = +/- 0.6 LSB (slightl INL = +/- 1.2 LSB My first question is that is this peformance satisfactory or acceptable at 12-bit level ? (Our aim was to have 12-bit absolute accuracy). I looked into commercial ADC and I found a wide variety of DNL and INL numbers there. The second question is that what tests I can conduct to get more insight as what´s not "relatively" working. We have switched capacitor gain stage, comparator etc in there. |
Title: Re: Debugging 12-bit ADC Silicon Post by loose-electron on Sep 15th, 2006, 12:36pm Acceptable depends totally on your performance requirment, INL, DNL, ENOB, etc, etc, -- ergo, what do you need? As for tests - what did you include in the design to access all the parts and pieces? You cant get in there with a scope probe and some clip leads, so test circuits, the capability to test multiplex and those sort of things need to be inherent to the design being fabricated. |
Title: Re: Debugging 12-bit ADC Silicon Post by Faisal on Sep 18th, 2006, 2:34am the target was to achieve 12-bit absolute accuracy (but wanted to know, with the numbers I described before, if it was still okay or almost okay to call it a 12-bit ADC) Did not put any DFT (Design for test) things in there. I want to narrow down what was not relatively working E.g. a)Is the opamp gain in silicon comparable to what we meausre in simulation (e.g 100 dB in simulation, but if 80 dB in silicon can spoil the results) b) Was the capacitor matching good enough (1 to 2 percent) ? How do I know for sure ? c) Are my capacitors non-linear over the voltage range, I am using etc ? (in silicon) So its the kind of parameteric faults/features I am interested in knowing ? Any pointers in this regard would be helpful (e.g. test circuits I can design on IC to measure these) |
