https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> reset/sampling noise https://designers-guide.org/forum/YaBB.pl?num=1158245764 Message started by elp03ta on Sep 14th, 2006, 7:56am |
Title: reset/sampling noise Post by elp03ta on Sep 14th, 2006, 7:56am I would like to know if i can simulate the sampling (kTC) noise with spectre or do i need spectreRF. Further is it possible to simulate hard and soft reset for a 3 transistor active pixel sensor. Thanks |
Title: Re: reset/sampling noise Post by MK on Sep 23rd, 2006, 3:44pm Hi, I am also facing a similar problem. Where you able to figure out how to simulate your circuit? |
