https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Noise Figure based on rmsnoise https://designers-guide.org/forum/YaBB.pl?num=1159375946 Message started by ezencir on Sep 27th, 2006, 9:52am |
Title: Noise Figure based on rmsnoise Post by ezencir on Sep 27th, 2006, 9:52am Hello All, NF equation says NF=10*log10(Vn,out**2/(A**2*4kTRs)) where A is the voltage gain from source to output, and Rs is the source impedance. How can I get Vn,out**2 term from rmsNoise function of Cadence? In other words, what is the exact Analog Design Environment output expression to calculate NF? Thanks for the feedback. |
Title: Re: Noise Figure based on rmsnoise Post by ACWWong on Sep 27th, 2006, 11:53am you should use the "add to outputs button" to get the expression under the results->direct plot-> main form of the ADE GUI. So output squared rms noise is: getData("out" ?result "noise")**2 likewise the noise figure is: getData("NF" ?result "noise") the use of the rmsNoise funtion integrated the noise over a certain bandwidth. Normally one plots NF(f) using Av(f) and vn(f) so the rmsNoise calculator function might not be that useful. |
