https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Folded cascode opamp https://designers-guide.org/forum/YaBB.pl?num=1160108545 Message started by hande.vinayak on Oct 5th, 2006, 9:22pm |
Title: Folded cascode opamp Post by hande.vinayak on Oct 5th, 2006, 9:22pm Hi, I wanted to design a opamp with UGB 180Mhz with PM around 50 degrees and open loop gain 65dB.As per this spec. can you help me to decide a proper opamp config.If anybody is having a papera regarding folded cascode,can you like share with me? Thanks. |
Title: Re: Folded cascode opamp Post by bharat on Oct 5th, 2006, 10:30pm Folded cascode is preferred because of head room issue. If you are good in head room there is no need of folded cascode. I believe in KISS (keep it simple and small ) philosophy. Bias generation is little tricky in folded cascode. -Bharat |
Title: Re: Folded cascode opamp Post by hande.vinayak on Oct 6th, 2006, 3:27am Thanks Bharat. Can you suggest any paper in the case of Fully Differential FC OTA? Thnx. |
Title: Re: Folded cascode opamp Post by Raul on Oct 10th, 2006, 2:25pm Are you only driving capacitance? If so, a folded-cascode is the best option. |
Title: Re: Folded cascode opamp Post by packiaraj on Oct 11th, 2006, 8:40pm Look for the attached JSSC paper on Fully Differential Folded Cascode OTA Design. Thanks, Packiaraj.V. |
Title: Re: Folded cascode opamp Post by jbdavid on Oct 11th, 2006, 11:07pm Unless that was YOUR paper, its covered by an IEEE copyright.. ok even if it was its covered, but IEEE allows you to distribute a few copies of your own paper.. In either case, posting it to a website like this is illegal! It would be better to post a link http://ieeexplore.ieee.org/xpls/abs_all.jsp?isnumber=1702&arnumber=45013&count=38&index=31 |
Title: Re: Folded cascode opamp Post by hande.vinayak on Oct 12th, 2006, 12:14am Thanks Packiaraj.V.,it really helped me a lot. |
Title: Re: Folded cascode opamp Post by packiaraj on Oct 12th, 2006, 1:56am I thought before posting....but ?... OK David... Taken... Thanks, Packiaraj.V. |
Title: Re: Folded cascode opamp Post by SATurn on Oct 12th, 2006, 9:17am Please remind that if load capacitor is large, then it is very difficult to achieve the desired specs. In this case you must use another class of amplifier (e.g., class-AB) ... |
