https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> N2PORT DC problem https://designers-guide.org/forum/YaBB.pl?num=1160643484 Message started by uncle_ezra on Oct 12th, 2006, 1:58am |
Title: N2PORT DC problem Post by uncle_ezra on Oct 12th, 2006, 1:58am Hi, I have s-parameter data of a balun and tried importing into spectre using N2PORT. However when I run simulation it cannot give me the correct DC value. I have ran the s-parameter data down to 0 Hz but the problem persists. Is there a way around this problem, other than use another tool such as ADS? Thanks |
Title: Re: N2PORT DC problem Post by vara on Oct 12th, 2006, 4:39am Uncle, Try 'rational' for the interpolation method in the 'n2port' instance. I had to import from an other tool like you did and it works for me in ac analysis. However, for Transient analysis, 'rational' does not work and i read somewhere (don't remember where) that 'spline' should be used. Vara |
Title: Re: N2PORT DC problem Post by vara on Oct 12th, 2006, 4:44am See attachement |
Title: Re: N2PORT DC problem Post by uncle_ezra on Oct 12th, 2006, 5:49pm Thanks, I tried using 'rational' but it did not work. Basically what I have is a balun where in the primary one port is connected to VDD and the other to the signal and the secondary is a differential output. So when I run transient or DC analysis I get garbage since there are no DC voltage or current flowing from VDD to the main circuit. |
Title: Re: N2PORT DC problem Post by madengr on Oct 13th, 2006, 2:04pm I noticed you are using Sonnet. It will export a lumped element equivalent circuit that may work, assuimg it generates a low-pass structure. |
Title: Re: N2PORT DC problem Post by Andrew Beckett on Jan 15th, 2007, 2:32am Bit late in replying, but probably I would suggest using spline or linear as the interpolation method. I'd also recommend setting "Use smooth data windowing" to "yes" - this is nearly always the right thing to do; failure to do this often leads to an error in the DC value (but is more accurate if you have signals close to the maximum frequency in the s-parameter data). There is an application note on sourcelink (search for "nport application note") which covers the parameters well. Regards, Andrew. |
