https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> [q] verilog-a in hspice https://designers-guide.org/forum/YaBB.pl?num=1162931715 Message started by kidhyun on Nov 7th, 2006, 12:35pm |
Title: [q] verilog-a in hspice Post by kidhyun on Nov 7th, 2006, 12:35pm Hi, Pleae let me know how to pass parameters when I instantiate verilog-a module in hspice. For example, there is a resistor module in verilog-a. Then in hspice I have to do .hdl 'resistor.va' x1 a b resistor // when resistor is the module name The how can I pass a parameter value (resistor value) here? Do I have to make seperate verilog-a module for each resistor with different resistance? Thank You |
Title: Re: [q] verilog-a in hspice Post by Geoffrey_Coram on Nov 8th, 2006, 10:27am Did you try x1 a b resistor r=10k where "r" is the parameter declared in the module? I believe the HSpice implementation also allows model cards, eg x1 a b myres .model myres resistor r=10k |
