https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> How to chose seed? https://designers-guide.org/forum/YaBB.pl?num=1163658055 Message started by neoflash on Nov 15th, 2006, 10:20pm |
Title: How to chose seed? Post by neoflash on Nov 15th, 2006, 10:20pm How we choose the value of seed, of random number generator and how it affects? Does this number play any role, besides specify a determistic start point? What if I chose seed=111? |
Title: Re: How to chose seed? Post by neoflash on Nov 15th, 2006, 10:21pm attach the sample usage here: dT = jitter*$rdist_normal(seed,0,1); |
Title: Re: How to chose seed? Post by Geoffrey_Coram on Nov 16th, 2006, 11:24am As far as I know, it's just a start point in the sequence of pseudo-random numbers. |
Title: Re: How to chose seed? Post by neoflash on Nov 16th, 2006, 5:03pm I have attached one sample code from this website, why author chose seed=286, not other number? module osc2 (out); output out; voltage out; // output signal parameter real freq=1 from (0:inf); // output frequency parameter real vl=-1; // high output voltage parameter real vh=1; // low output voltage parameter real tt=0.01/freq from (0:inf); // transition time of output parameter real jitter=0 from [0:0.1/freq); // white period jitter integer n, seed; real next, dT; analog begin @(initial_step) begin seed = 286; next = 0.5/freq + $abstime; end @(timer(next)) begin n = !n; dT = jitter*$rdist_normal(seed,0,1); next = next + 0.5/freq + `M_SQRT1_2*dT; end V(out) <+ transition(n ? vh : vl, 0, tt); end endmodule |
Title: Re: How to chose seed? Post by Ken Kundert on Nov 16th, 2006, 7:20pm It was a completely arbitrary choice. The only criteria I used was to use a different seed for each rdist function present in the system. If you give the same seed to two different rdist functions they will produce an identical sequence of random numbers. -Ken |
Title: Re: How to chose seed? Post by Geoffrey_Coram on Nov 17th, 2006, 5:54am Ken Kundert wrote on Nov 16th, 2006, 7:20pm:
By "two different rdist functions" Ken does not mean to say that $rdist_normal() and $rdist_uniform will give the same sequence of random numbers. I am fairly sure he meant "give the same seed to two different calls of the same rdist function": Modifying the example: integer n, seed, seed2; real next, dT, dT2; analog begin @(initial_step) begin seed = 286; seed2 = 286; next = 0.5/freq + $abstime; end @(timer(next)) begin n = !n; dT = jitter*$rdist_normal(seed,0,1); dT2 = jitter*$rdist_normal(seed2,0,1); // will have the same sequence of values as dT next = next + 0.5/freq + `M_SQRT1_2*dT; end V(out) <+ transition(n ? vh : vl, 0, tt); end dT2 will have the exact same sequence of random values as dT. Also, seed and seed2 are changed by the $rdist function calls, and the sequence of their values will be the same. I wonder: if you did rn1 = $rdist_normal(seed,0,1); rn2 = $rdist_uniform(seed2,-1,1); will "seed" and "seed2" have the same sequence of (integer) values? I guess you might or might not, since the LRM doesn't say. -Geoffrey |
