https://designers-guide.org/forum/YaBB.pl Modeling >> Behavioral Models >> string parameter?? https://designers-guide.org/forum/YaBB.pl?num=1165351394 Message started by Aigneryu on Dec 5th, 2006, 12:43pm |
Title: string parameter?? Post by Aigneryu on Dec 5th, 2006, 12:43pm Dear all, Can we pass a string parameter into an instance for a verilog-A macro? I know there are real, integer,.. but I cannot find anything about the string. Can somebody tell me if it is possible or not? |
Title: Re: string parameter?? Post by Geoffrey_Coram on Dec 6th, 2006, 4:13am I don't think you meant string parameter. I believe your question should have been: is it legal to use a string literal as an actual argument for a macro? And the answer is: yes. For example, if you define this: `define mydebug(x) $strobe("DEBUG: ", x) then you should be able to call it with the string literal "line 101" `mydebug("line 101") If you really were asking about string parameters, they were added to Verilog-AMS LRM 2.2, and maybe that's why you can't find them where you are looking; they're not supported by all simulators yet. I'm not exactly sure what your question is; are you trying to override an instance parameter? Or trying to pass a string parameter as the argument to a macro? Using the definition above, if you also have parameter string myname = "X1"; you should be able to `mydebug(myname) -Geoffrey |
Title: Re: string parameter?? Post by Aigneryu on Dec 6th, 2006, 6:26pm Thanks Geoffrey, That's exactly the information I need. |
