https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> saving .op points such as gm, cgg etc. https://designers-guide.org/forum/YaBB.pl?num=1166164602 Message started by smchiu on Dec 14th, 2006, 10:36pm |
Title: saving .op points such as gm, cgg etc. Post by smchiu on Dec 14th, 2006, 10:36pm Hi Andrew, I have come across your solution to this problem in Google group before. Basically I want to observe the Id/W vs. gm/Id. I know that by default Cadence only save its operating point once for dc analysis, and your previous solution suggests using, say, savedata.scs file and in it type: save M0:gm for example. I have tried it and stuggled for many weeks, but the following error still occur (Interestingly, I find no problem using OP("/M0" "gm") etc, or even just using parametric analys (but it takes a long time, and is inconvenient): " Warning from spectre during initial set up. 'M0': Does not have a terminal named 'gm'. Ignoring invalid item 'M0:gm' in save statement " Here's how my input.scs file looks like, please help....: // Generated for: spectre // Generated on: Dec 14 22:14:45 2006 // Design library name: 90nm // Design cell name: findgmId // Design view name: schematic simulator lang=spectre global 0 vdd! include "~/course/eece588/project/90nm/savedata.scs" include "models" parameters vdsn=0 vdsp=0 vgsn=0.7 vgsp=0.7 w_pmos=10 w_nmos=10 \ vgs=0.3627254509018039 vin=0 len=0.1 // Library name: 90nm // Cell name: findgmId // View name: schematic M7 (net030 0 net052 vdd!) plvt w=43.6 l=0.1 nfing=1 mult=1 srcefirst=1 \ mismatch=1 M4 (net12 net045 vdd! vdd!) plvt w=w_nmos l=len nfing=1 mult=1 srcefirst=1 \ mismatch=1 M5 (net039 net047 vdd! vdd!) plvt w=43.6 l=0.1 nfing=1 mult=1 srcefirst=1 \ mismatch=1 M6 (net030 vdd! net052 0) nlvt w=21.82 l=0.1 nfing=1 mult=1 srcefirst=1 \ mismatch=1 M0 (net040 net044 0 0) nlvt w=w_nmos l=len nfing=1 mult=1 srcefirst=1 \ mismatch=1 M1 (net042 net050 net046 0) nlvt w=21.82 l=0.1 nfing=1 mult=1 srcefirst=1 \ mismatch=1 V11 (net030 0) vsource dc=vin-0.001*vin type=dc V10 (net052 0) vsource dc=vin type=dc V7 (net042 0) vsource dc=1.000m type=dc V4 (vdd! net047) vsource dc=vgs type=dc V6 (net045 net12) vsource dc=0 type=dc V8 (vdd! net039) vsource dc=1m type=dc V9 (net046 0) vsource dc=vin type=dc V3 (net050 0) vsource dc=1 type=dc V5 (net044 net040) vsource dc=0 type=dc V0 (net044 0) vsource dc=vgs type=dc V1 (vdd! net045) vsource dc=vgs type=dc V2 (vdd! 0) vsource dc=1 type=dc simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=27 \ tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \ digits=5 cols=80 pivrel=1e-3 ckptclock=1800 \ sensfile="../psf/sens.output" checklimitdest=psf dcOp dc write="spectre.dc" maxiters=150 maxsteps=10000 annotate=status dcOpInfo info what=oppoint where=rawfile Looking forward to your reply. Thank you. David. |
Title: Re: saving .op points such as gm, cgg etc. Post by Geoffrey_Coram on Dec 15th, 2006, 4:14am I think if you save M0:all then you get all the operating-point info. More than you need, but should get what you want. |
Title: Re: saving .op points such as gm, cgg etc. Post by smchiu on Dec 15th, 2006, 10:29am Hello, Thanks for your reply. I did try that before and get the following message: "Warning from spectre during initial setup. subcktInst: ID disallowed temporarily (till?). Ignoring invalid item 'M0:all' in save statement." Any thought how to sort that out? I have been struggling with this for a long while yet not able to figure out the solution to that regardless of the fact of the solutions people posted. <sigh> If anyone could lend me a hand, that will be highly appreciated!!!!!! ;D ;D David. |
Title: Re: saving .op points such as gm, cgg etc. Post by Geoffrey_Coram on Dec 18th, 2006, 6:41am Is M0 an instance of a subckt? In that case, you need to know the name of the device inside, I think, such as <M0>M. |
Title: Re: saving .op points such as gm, cgg etc. Post by Ken Kundert on Dec 18th, 2006, 11:53am Or you can make the subcircuit an inline subcircuit, in which case you would get the operating point information for the inlined component. -Ken |
Title: Re: saving .op points such as gm, cgg etc. Post by smchiu on Dec 18th, 2006, 12:05pm Hello everyone, I am grateful for all your replies! I tried to use ocean interactively and requested the results output. I discovered that you are totally correct. Now, in the savedata.scs, I use this: save M0.m1.gm It seems that for some reasons, I have to include m1 after M0, don't know the reason why though. Ken, could you illustrate a little bit more how to include the circuit inline? The transistor model is taken from the 90nm process and I don't know how to do that. Thank you so much. Merry Christmas guys! You are so helpful. David. |
Title: Re: saving .op points such as gm, cgg etc. Post by Geoffrey_Coram on Dec 18th, 2006, 12:27pm Ken Kundert wrote on Dec 18th, 2006, 11:53am:
The subcircuit definition is probably in the library file, which I think would mean the user can't modify it. Don't you need to specify the "inline" as part of the definition? Or can you force spectre to treat it as inline even though it's defined otherwise? David - In your netlist, you have something like: M0 (d g s b) nmos w=1u l=1u Now, usually, one would then find in the library file the corresponding definition: model nmos bsim3v3 version=3.24 vth=0.7 ... Instead, in your case, the "nmos" is defined as a subckt, which might look like this: subckt nmos (d g s b) w=10u l=10u rd d di 0.5 rs s si 0.5 m1 (di g si b) nmos_mod w=$w l=$l ends and then "nmod_mod" is defined with a "model card" to be a bsim3v3 device. The subckt "nmos" doesn't have a "gm" -- it's the mos device inside the subckt that has the operating point info. |
Title: Re: saving .op points such as gm, cgg etc. Post by smchiu on Dec 18th, 2006, 1:54pm Hello Geoffrey, Thanks a lot for your answer. I completely understand now! Thanks. David. |
Title: Re: saving .op points such as gm, cgg etc. Post by Ken Kundert on Dec 18th, 2006, 10:17pm As Geoffrey says, to make a subcircuit inline, you have to modify the definition of the subcircuit rather than the instantiation, which is generally not an option for the user if the subcircuit is defined in a library that is not user modifiable (in this case the inlining is generally done by the author of the library). To show how to do it I will modify Geoffrey's example. The subcircuit definition becomes Quote:
Now if you instantiate a MOS with Quote:
You can use Quote:
to save the gm of M0.nmos. The inlining causes any request that cannot be serviced by the subcircuit to be passed to the inline device, in this case nmos. It is the inline device because it has the same name as the inline subcircuit name. -Ken |
