https://designers-guide.org/forum/YaBB.pl Modeling >> Behavioral Models >> How to parameterize a string variable https://designers-guide.org/forum/YaBB.pl?num=1166211680 Message started by naone on Dec 15th, 2006, 11:41am |
Title: How to parameterize a string variable Post by naone on Dec 15th, 2006, 11:41am I am trying to pass a string parameter into a verilogA file to use as the filename for an include file: This is what I am trying but have syntax errors: parameter filename = "incfile.txt" `include filename This does not work. I also tried `include(filename) and this did not work either. Any help is greatly appreciated. Naone |
Title: Re: How to parameterize a string variable Post by Geoffrey_Coram on Dec 18th, 2006, 6:31am I'm almost sure you can't do this at all; the problem is that `include is a preprocessor directive, handled by the compiler, well before anything else happens. What are you trying to bring in in that include file, though? Usually, include files tell the compiler something about how to compile; I guess you're trying to bring in some information for simulation, so you may be able to bring in the data another way (eg, $table_model). -Geoffrey |
Title: Re: How to parameterize a string variable Post by jbdavid on Feb 9th, 2007, 3:13am If you want to set some variables from the file, you can use parameter string myFile = "default file name" then FH = $fopen( myFile, r): <- I don't remember how this works var1 = $fscanf(FH); |
Title: Re: How to parameterize a string variable Post by Geoffrey_Coram on Feb 9th, 2007, 6:19am jbdavid wrote on Feb 9th, 2007, 3:13am:
In what simulator? I know it's in the LRM; I'm not aware of any simulators that support it yet ... |
Title: Re: How to parameterize a string variable Post by Andrew Beckett on Feb 22nd, 2007, 11:09am Spectre does. I filed a PCR a while ago because string parameters weren't working in case statements, but that works now (in MMSIM60 and MMSIM61 versions for about a year). I just took the example I had with a case statement, and tried it out with fopen too - and that worked: Code:
with this netlist: Code:
It wrote out: rtype is M2, rval is 1600 both to the screen, and into a file called "M2". Regards, Andrew. |
