https://designers-guide.org/forum/YaBB.pl Measurements >> RF Measurements >> Gm https://designers-guide.org/forum/YaBB.pl?num=1166422179 Message started by sivacharan on Dec 17th, 2006, 10:09pm |
Title: Gm Post by sivacharan on Dec 17th, 2006, 10:09pm To measure the transconductance of the mixer i used QPSS analysis. But after running the simulation, i clicked on the output node of the port. But the tool is saying "res/PLUS is not a kept output". What does it mean?? Thank you. |
Title: Re: Gm Post by didac on Dec 17th, 2006, 11:07pm Hi, Without more info I guess that the Mixer output is in current mode. If you want to see a current in Spectre you must first select like an Outputs-->to be saved. After saving it in the form you can run the simulation and you can view the output without further problems. |
Title: Re: Gm Post by sivacharan on Dec 18th, 2006, 12:10am didac, yes, my mixer output is current. i didn't save the output node to plot current. i got the result after saving the output node on the outputs list. Thank you didac.... |
