https://designers-guide.org/forum/YaBB.pl Design Languages >> VHDL-AMS >> How to simulate VHDL AMS models using cadence AMS https://designers-guide.org/forum/YaBB.pl?num=1166422254 Message started by chviswanadh on Dec 17th, 2006, 10:10pm |
Title: How to simulate VHDL AMS models using cadence AMS Post by chviswanadh on Dec 17th, 2006, 10:10pm Hello, I need to verify a mixed signal design which has some components modelled in VHDL AMS. Till now we were using verilog models. Can anybody help me out how to simulate these designs using Cadence AMS simulator Thanks Chviswanadh |
Title: Re: How to simulate VHDL AMS models using cadence Post by zhong on Dec 19th, 2006, 11:13pm Nothing special for VHDLAMS setup if you are familer with Cadence AMS Designer . You can generate VHDLAMS in DFII cell view creation or compile text into DFII by ncvhdl -ams then In HED , switch view binding to vhdlams view or whatever the view name you generated which include vhdlams contents . Then You are all set for kick off the simulation from this HED config. Please reference Cadence AMS user guide for how to kick off AMS simulation. |
Title: Re: How to simulate VHDL AMS models using cadence Post by chviswanadh on Dec 20th, 2006, 4:28am Hello zhong, Thanks for the reply. I am able to create the symbol view of the VHDL AMS model and config view. In the config view I selected the view list as entity since the vhdlams are related to this view. But when I try to simulate, simulator is unable to recognise the port teminals as ports that are declared in the code. Any comments on this. Thanks chviswanadh |
Title: Re: How to simulate VHDL AMS models using cadence Post by zhong on Dec 21st, 2006, 12:49am In HED swith to the view name defined in VHDLAMS architecture . For example entity my_block is port(a1 , b1 : in std_logic; y1 : out std_logic_ ; end entity my_block ; architecture behavior of my_block is .... end architecture behavior After you compile this into DFII via ncvhdl -use5x , you will see view "behavior" . switch to behavior view instead of "entity" view in HED . |
Title: Re: How to simulate VHDL AMS models using cadence Post by chviswanadh on Dec 21st, 2006, 8:56am Hello Zhong, I have tried including the architecture name in the view list still it gives the same error. Any comments on this Regards chviswanadh |
Title: Re: How to simulate VHDL AMS models using cadence Post by zhong on Dec 21st, 2006, 7:20pm chviswanadh , Not only in HED view list , In HED , instead of binding to "entity" , bind the cell to architecture name/view in HED cell view binding. Please also check if ports in symbol are same as the ports declared in entity. BTW, What is the specific errors you have seen ? Zhong |
Title: Re: How to simulate VHDL AMS models using cadence Post by chviswanadh on Dec 24th, 2006, 4:35am Hello Zhong, Thanks for the help. I have included vhdlams view in the HED viewlist. Now it works fine. Thanks Chviswanadh |
