https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> about VCO modeling https://designers-guide.org/forum/YaBB.pl?num=1166581661 Message started by jeffyan on Dec 19th, 2006, 6:27pm |
Title: about VCO modeling Post by jeffyan on Dec 19th, 2006, 6:27pm hi all, we usesually model the voltage-controlled oscillator like this: f=Kvco * Vc. and Kvco is extracted by a dc sweep of Vc. but i want to question that whether Kvco is frequency dependent? if yes, why we ignore it? thanks, jeff |
Title: Re: about VCO modeling Post by ywguo on Dec 21st, 2006, 8:24pm Jeff, Do you want to make the model too complex? Obviously, probably the PLL is not stable if Kvco is frequency dependent. BG Yawei |
Title: Re: about VCO modeling Post by jeffyan on Dec 21st, 2006, 9:05pm HI, i think, the reason why we ignore the frequency-depedance of Kvco, is Kvco(f) is of a low-pass property, and its cut-off frequency is larger than PLL' bandwidth. this is my own opinion for your consideration. jeff |
Title: Re: about VCO modeling Post by ywguo on Dec 25th, 2006, 1:38am Jeff, I don't understand why Kvco is of a low-pass property? Would you please explain it or present an example? Thanks Yawei |
