https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> Purpose of this resistor in LC-VCO https://designers-guide.org/forum/YaBB.pl?num=1167641764 Message started by neoflash on Jan 1st, 2007, 12:55am |
Title: Purpose of this resistor in LC-VCO Post by neoflash on Jan 1st, 2007, 12:55am Why there is a 2.5k ohm resistor on the control line? What is that for? |
Title: Re: Purpose of this resistor in LC-VCO Post by ACWWong on Jan 1st, 2007, 4:33am There are couple of reasons depending on the nature of the control line signal. If the control lines signal is an analogue tuning voltage, then the 2.5kohm forms a high frequency pole for the tuning line and part therefore is part of the loop filter. It also acts as ESD robustness (the, especially if the control line goes to a pad/external world. If the control line is digital and used to either completely switch in/out the FETs in switched tank structure, then again the resistor adds ESD robustness, and acts to attenuate noise on the control line. cheers aw |
Title: Re: Purpose of this resistor in LC-VCO Post by rf-design on Jan 5th, 2007, 3:03am I share the first view from the first comment 1. Possible additional pole in the loop transfer function which make a third order PLL. The question is that for the same phase delay at the critical loop bandwidth frequency this could be more efficient be done by an multi-stage RC filter. 2. Do not short the second harmonic current in the loop filter cap. This could possible be a negative effect for PN. 3. Isolating noise from the digital control is more effective by using a buffer inverter which is conneted to clean supply. So questionable! |
