https://designers-guide.org/forum/YaBB.pl Simulators >> AMS Simulators >> error during elaboration https://designers-guide.org/forum/YaBB.pl?num=1168353800 Message started by krishnap on Jan 9th, 2007, 6:43am |
Title: error during elaboration Post by krishnap on Jan 9th, 2007, 6:43am I have the circuit setup and i'm trying to run the AMS simulation. At Design Prep stage, it successfully creates the netlist, but in the elaboration stage it gives the follwing warning. Affirma_AMS simulator currently doesnot support the 5.X configuration in combination with the prop.cfg used to describe analog primitives. I could simulate the above in spectre Can anybody suggest regarding this? |
Title: Re: error during elaboration Post by Andrew Beckett on Jan 16th, 2007, 4:02pm Being able to simulate in spectre doesn't really mean that much... AMS is simulated rather differently. Are you specifying properties for specific instances or cells? For example, the view to use set to sourcefile? It's hard to know without seeing what you're doing. Can you look in your library in the config view you're using, and see if there's a file in there called prop.cfg - if so, can you post it here? Also, what version are you using (of the simulator, and the envrionment) (ncsim -version and icfb -W will reveal this info) Regards, Andrew. |
Title: Re: error during elaboration Post by krishnap on Jan 18th, 2007, 5:11am Hi Andrew following are the version for ncsim and icfb. TOOL: ncsim 05.70-s007 icfb:sub-version 5.10.41.500.3.49 Also attaching the zipped version of prop.cfg file Thanks and regards, Krishna |
Title: Re: error during elaboration Post by Andrew Beckett on Jan 22nd, 2007, 4:13am Well, there are two options: 1. specify on the AMS->Options->Elaborator in the [] Additional Arguments field, -propspath /path/to/your/prop.cfg file I've got a request in somewhere to do this automatically, but it doesn't for some reason 2. In this case just delete the prop.cfg file from the cellView, since it is effectively empty. Regards, Andrew. |
Title: Re: error during elaboration Post by krishnap on Jan 23rd, 2007, 10:23pm Hi Andrew , I tried with the options, still it gives the same error. could you suggest, Best regards, Krishna |
Title: Re: error during elaboration Post by Andrew Beckett on Jan 24th, 2007, 2:38pm Really? You deleted the props.cfg file and it still gives that error? That seems very unlikely... Can you double check that you've deleted it from the right place? Regards, Andrew. |
Title: Re: error during elaboration Post by krishnap on Jan 30th, 2007, 5:55am Hi Andrew, I have deleted the prop.cfg file in the path. /home/testcase/SWITCHSIM/config, and in the elaborator options added following for additional arguments: -propspath /home/testcase/SWITCHSIM/config It gives the same error. Could you suggest Thanks and regards, Krishna |
Title: Re: error during elaboration Post by Andrew Beckett on Feb 7th, 2007, 4:15am Well, you don't want to delete it AND add the -propspath - since you're then pointing at the props.cfg file that doesn't exist. However, the -propspath should include the name of the actual prop.cfg file if you were going to do this, not the name of the directory it is contained within. Regards, Andrew. |
