https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> how to convert spectre netlist to hspice netlist https://designers-guide.org/forum/YaBB.pl?num=1168609917 Message started by jobless on Jan 12th, 2007, 5:51am |
Title: how to convert spectre netlist to hspice netlist Post by jobless on Jan 12th, 2007, 5:51am is there a way to convert spectre netlist into hspice ? |
Title: Re: how to convert spectre netlist to hspice netli Post by Andrew Beckett on Jan 12th, 2007, 5:57am The easiest way would be to write a perl script, but in IC610, you could use File->Import->SPICE (I think that's the menu) which can create a real schematic from a spectre netlist, and then you could netlist that in the hspiceD interface in ADE. Regards, Andrew. |
Title: Re: how to convert spectre netlist to hspice netli Post by simon2 on Sep 20th, 2007, 4:29pm ... try this in Wordpad (although for some search and replace functions, Word might be better) *************************************************************************** *** Spectre to Hspice *** // ** *** \ <return> + *** Inn Xnn *** subckt .sub *** ends .ends *** resistor r= (empty) *** capacitor c= (empty) *** sa, sb, sca, scb (comment out) NB: ignored in Spectre & Hspice *** scc in MOS (comment out) NB: ignored in Spectre & Hspice *** (Vdc3/2) 'Vdc3/2' brackets ( ) to single quotes ' ' *** Rnn n1 n2 rppolywo XRnn n1 n2 rppolywo *************************************************************************** You may have to write a subckt for XRnn depending on the foundry model files you are using. I find the above covers most cases. Cheers, SimonH. |
