https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> HSPICE writing .print results to file https://designers-guide.org/forum/YaBB.pl?num=1168616591 Message started by Alm on Jan 12th, 2007, 7:43am |
Title: HSPICE writing .print results to file Post by Alm on Jan 12th, 2007, 7:43am Hello, Is there a way for getting HSPICE to write the .print results to a file instead of on the screen? If I simply write hspice file1.spice > out1.spice the entire output including spice netlist, model files get written. I want to avoid that and only write the results obtained using .PRINT statement. ie .print V(I2) If the above is not possible, is the only possible option to get the entire out file and write some scripts to pick up the relevant information? Thanks, Alm |
Title: Re: HSPICE writing .print results to file Post by Geoffrey_Coram on Jan 12th, 2007, 7:59am There's .OPTIONS NOMOD that suppresses playback of the model cards (available even in Spice3f5). One simulator I worked with had .OPTIONS BRIEF that would turn off everything until .OPTIONS BRIEF=0 was encountered, don't know if it works in HSpice. |
Title: Re: HSPICE writing .print results to file Post by Alm on Jan 12th, 2007, 8:11am Thanks. That suppress almost everything except the operating point information. Any way to suppress that too? -Alm |
