https://designers-guide.org/forum/YaBB.pl Simulators >> AMS Simulators >> Cadence internal error troubleshooting https://designers-guide.org/forum/YaBB.pl?num=1169821554 Message started by Pavel on Jan 26th, 2007, 6:25am |
Title: Cadence internal error troubleshooting Post by Pavel on Jan 26th, 2007, 6:25am Hello After eleborating my design I receive following error message in Hierarchy Editor Message window: ncelab: *internal* (dlib_write - invalid abstract name - no such library). Please contact Cadense Design Systems about this problem and provide enouph information to help us reproduce it. I'm unawre of what is dlib_write, as I have nothing like this in my design. Contact to Cadence technical support means wait for some days. Did anybody encounter *internal* error? Is there some means to troubleshoot it, as there is no any suggestion from tool. Thanks. Pavel. |
Title: Re: Cadence internal error troubleshooting Post by Andrew Beckett on Jan 26th, 2007, 6:31am Pavel, This may (from a little bit of searching) be due to an illegal name being used as the library name. Does the library name begin with a number, or have any punctuation in it? How about the module name(s). There's a PCR to improve the error message, but from reading between the lines, I believe this is due to invalid names being used... Regards, Andrew. |
Title: Re: Cadence internal error troubleshooting Post by Pavel on Jan 26th, 2007, 7:00am Thank you for answer, Andrew, Effectively, I had 2 libraries, that start with numbers. I renamed them, and now am trying with new names. I'll inform you results. Best regards. Pavel. |
Title: Re: Cadence internal error troubleshooting Post by Pavel on Jan 26th, 2007, 7:22am Andrew, I renamed libraries, refreshed modules (HE->View->Refresh), deleted *.pak files, deleted cds_global cell from "root" library and run. The result of was following Error message window: AMS Create Globals Module: Error Couldn't create and/or compile the cds_globals cell view. and following message in Hierarchy Editor Message window: Cannot find FMP view for cds_global cellview. "old_library_name".cds_globals:"top_level_cell"_config Couldn't create and/or compile the cds_globals cell view I closed design and run icms from 0. It didn't help. How could I suppress the links to old library? Best regards. Pavel. |
Title: Re: Cadence internal error troubleshooting Post by Pavel on Jan 26th, 2007, 8:35am Problem resolved I'm aware of nature of error mesages, but suppressing and creating one more time of config view for top-level cell resolve the problem. Andrew thank you for the trail. Regards Pavel. |
