https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> OCEAN vim syntax https://designers-guide.org/forum/YaBB.pl?num=1170097524 Message started by Visjnoe on Jan 29th, 2007, 11:05am |
Title: OCEAN vim syntax Post by Visjnoe on Jan 29th, 2007, 11:05am Dear all, does anyone have a VIM syntax file for OCEAN scripts? A quick Google search did not provide anything... Kind Regards Peter |
Title: Re: OCEAN vim syntax Post by Andrew Beckett on Jan 29th, 2007, 2:34pm Simplest thing to do is to create a directory ~/.vim and create a file within that called filetype.vim with the following contents: Code:
This will tell it to treat files with the suffix .ocn as SKILL code (which is what OCEAN is). Regards, Andrew. |
Title: Re: OCEAN vim syntax Post by jbdavid on Feb 1st, 2007, 2:11am I have a .pats file for SKILL that works for OCEAN - but thats for Nedit editor.. |
