https://designers-guide.org/forum/YaBB.pl Simulators >> AMS Simulators >> time measurements in SimVision https://designers-guide.org/forum/YaBB.pl?num=1170255549 Message started by Pavel on Jan 31st, 2007, 6:59am |
Title: time measurements in SimVision Post by Pavel on Jan 31st, 2007, 6:59am Hello How to measure time between 2 pulse transitions in SimVision. by default, tool measures time between active cursor and baseline. But baseline cannot be stuck to edge. I didn't find how to measure time between 2 cursors. Regards. Pavel. |
Title: Re: time measurements in SimVision Post by jbdavid on Feb 1st, 2007, 1:58am you can add a second cursor, or drag the baseline to the time point you want to use as your referecne |
Title: Re: time measurements in SimVision Post by Pavel on Feb 1st, 2007, 2:21am Thank you for answer Quote:
I didn't find how to measure between 2 cursors. Quote:
Baseline can't be alligned precisely (stuck) to pulse edge. Regards. Pavel. |
Title: Re: time measurements in SimVision Post by zhong on Feb 3rd, 2007, 11:46am Pravel, You can do that. It's easy as bellow . You have TimeA cursor as default . You can creat a new cursor in Simvision call TimeB (See a little pull-down field in upper-left corner of simvision) Both TimeA and TimeB can stick with edge. Say you fixed the timeA first and move move TimeB to next stage . Again in upper left side of simvision, you can change the time delta from Cursor - baseline to cursor - timeA Hope this helps Zhong |
Title: Re: time measurements in SimVision Post by Pavel on Feb 5th, 2007, 4:51am Thank you for answer Zhong. Maybe we use different packages, because I didn't find option you proposed. Quote:
Could you attach some picture that shows your approach. Regards. Pavel. |
Title: Re: time measurements in SimVision Post by zhong on Feb 5th, 2007, 1:17pm In simvision upper left , click the down-direction arrow along with Cursor-baseline . A pull down show up , then select "delta" , then define the delta to be "cursor - timeA" |
Title: Re: time measurements in SimVision Post by zhong on Feb 5th, 2007, 1:18pm See attached pic. |
Title: Re: time measurements in SimVision Post by Pavel on Feb 6th, 2007, 1:30am Where ? (please see the picture) |
Title: Re: time measurements in SimVision Post by zhong on Feb 6th, 2007, 6:47am Looking your picture , It seems to me you are using very old version of simvision. Update to IUS57 or IUS58 , You can see the little arrow along with cursor-baseline and do what I mentioned in previous reply. (Sorry, somehow, I am not able to attach the picture from my disk.) |
Title: Re: time measurements in SimVision Post by Pavel on Feb 8th, 2007, 4:48am My SimVision version is 05.50-s008 |
Title: Re: time measurements in SimVision Post by zhong on Feb 8th, 2007, 9:40am IUS55-s008 is too old . Please update to IUS57 or IUS58 to see what I described in simvision. The latest version of IUS is IUS583-s001 . |
