https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> S/H droop https://designers-guide.org/forum/YaBB.pl?num=1170683115 Message started by Croaker on Feb 5th, 2007, 5:45am |
Title: S/H droop Post by Croaker on Feb 5th, 2007, 5:45am The capacitor voltage droops due to Ioff of the switch, the reverse-biased drain diode of the switch, and substrate current. I'm not seeing how substrate current comes into play. |
Title: Re: S/H droop Post by dkace on Feb 13th, 2007, 1:10am What if substrate current results on a lower Id and therefore a voltage drop across the switch, which eventually is presented as a voltage drop on the capacitor controled by this switch? What I am saying is that this is not adirect effect of the capacitor charge rather than on the MOST itself. What do you think? D. |
Title: Re: S/H droop Post by Croaker on Feb 13th, 2007, 7:56am I don't know. Hmm, I'm sure if I scrounge through my library I can find an explanation. Usually you need a few books on each subject to cover all the gaps one author creates. |
