https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Feature like IFDEF for Spectre? https://designers-guide.org/forum/YaBB.pl?num=1170774276 Message started by Daniel_Platte on Feb 6th, 2007, 7:04am |
Title: Feature like IFDEF for Spectre? Post by Daniel_Platte on Feb 6th, 2007, 7:04am Hi, I would like to change Spectre netlists controlled by an environment variable within a script-automated simulation. Is there a feature like IFDEF for the Spectre netlist parser? How can I access environment variables within the netlist? Example: -> if $DEBUG is set, add additional netlist entries to the simulation Thanks Daniel |
Title: Re: Feature like IFDEF for Spectre? Post by bernd on Feb 6th, 2007, 8:14am In my opinion this is not directly possible within the Analog Environment. I would use a programming language either SKILL or PERL to parse the netlist after it's creation and make the modification. Bernd |
Title: Re: Feature like IFDEF for Spectre? Post by Andrew Beckett on Feb 6th, 2007, 4:17pm If using spectre from the command line, you can use the -E option to spectre to tell it to use the C preprocessor before spectre parses it. For example: Code:
You can then use spectre -E -DMYDEF mynetlist.scs to pass in particular definitions from the outside. Regards, Andrew. |
Title: Re: Feature like IFDEF for Spectre? Post by Daniel_Platte on Feb 7th, 2007, 12:48am Thanks for the advice! Unfortunately, the C-preprocessor does not evaluate Spectre's include statement. As I would need the #ifdef in an options file (that is typically included with Spectre include), the C-preprocessor does not evaluate the #ifdef. Replacing all includes by #include does not solve the problem (and would be very tedious). Shouldn't the C-preprocessor evaluate the #include statements? Is it possible to combine Spectre's include and the #ifdef directive? |
Title: Re: Feature like IFDEF for Spectre? Post by Andrew Beckett on Feb 7th, 2007, 3:38am The C preprocessor does process the #include statements. But it won't process any files which are included with spectre's include statements - because these are processed after cpp has done its job. I can only assume you didn't replace all the includes with #includes? Regards, Andrew. |
