https://designers-guide.org/forum/YaBB.pl Modeling >> Semiconductor Devices >> Rout https://designers-guide.org/forum/YaBB.pl?num=1170901320 Message started by aaron_do on Feb 7th, 2007, 6:21pm |
Title: Rout Post by aaron_do on Feb 7th, 2007, 6:21pm Hi all, I was wondering how to calculate the MOSFET output impedance. I've come across two ways. Both seem correct. 1) based on channel length modulation, Rout ≈1/(lambda.IDS). 2) Based on reverse leakage through cgd, Gout ≈gm.Cgd/(Cgd+Cgs)=wT.Cgd. → Rout=1/(wT.Cgd). - This one assumes that the gate is left in open circuit. AS we can see neither of them are frequency dependent. Do I just add them in parallel? And which one tends to dominate (seems like the second one is quite a bit smaller for 0.18 um technology)? thanks, Aaron |
