https://designers-guide.org/forum/YaBB.pl Measurements >> Phase Noise and Jitter Measurements >> PLL Phase Noise profile problem https://designers-guide.org/forum/YaBB.pl?num=1171469792 Message started by HFG on Feb 14th, 2007, 8:16am |
Title: PLL Phase Noise profile problem Post by HFG on Feb 14th, 2007, 8:16am Hello All, Iam simulating schematic level simulations of phaselocked loops. I run PSS and Pnoise to generate the phaseNoise plot. Regardless of what type of PLL i design i get a phase noise slope of -10dBc/hz per decade but its suppose to be -20dBc/Hz per decade. I am pretty sure its not a circuit issume but a simulator problem. Will incorrect settings result in the wrong profile of the phase noise ? anyone run into this issue before ? |
Title: Re: PLL Phase Noise profile problem Post by Ken Kundert on Feb 14th, 2007, 9:04am Have you looked at the noise contributors summary? Where is the noise coming from? -Ken |
Title: Re: PLL Phase Noise profile problem Post by savithru on Jun 27th, 2007, 12:15am Hi ken, can you pls tell me how to look at the noise contributors summary? I could not find the menu in spectre RF. Thanks SavithRu |
