https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Instantiating a built-in model https://designers-guide.org/forum/YaBB.pl?num=1172401427 Message started by VerilogANovice on Feb 25th, 2007, 3:03am |
Title: Instantiating a built-in model Post by VerilogANovice on Feb 25th, 2007, 3:03am Hi all, Can I instantiate a built-in MOS model from Verilog-A? Thanks |
Title: Re: Instantiating a built-in model Post by zhong on Feb 25th, 2007, 11:52pm You can.. |
Title: Re: Instantiating a built-in model Post by VerilogANovice on Feb 26th, 2007, 12:39am Do you know how to do that in HSPICE? I am not sure how I can read in the model card in Verilog-A. |
Title: Re: Instantiating a built-in model Post by Geoffrey_Coram on Feb 26th, 2007, 5:23am The Verilog-AMS LRM does not specify how one defines model cards -- or the "library" for resolving model references -- in a Spice simulator. You'd need to check with an application engineer from Synopsys to find out how this works in HSpice. |
