https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Physical Verification, Extraction and Analysis >> Virtuoso Layout problem https://designers-guide.org/forum/YaBB.pl?num=1172405683 Message started by rsenthil78 on Feb 25th, 2007, 4:14am |
Title: Virtuoso Layout problem Post by rsenthil78 on Feb 25th, 2007, 4:14am Hello all, I import gds2 stream into virtuoso. WHen I open the Layout from LibraryManager I dont see the full layout that I see in FirstEncounter. Meaning I dont see the routing layers. DO I miss something while "Stream In"? I specified "Retain reference library(no merge) in Options. But still I dont see full layout. What is the problem ? your suggestions would be helpful! |
